10/22/2009 7:25 AM | |
Posts: 20 Rating:
Dear All, I am sending you the zipped version of the software where the Simocode block has been inserted. The block has been inserted in Chart H_BDM, page G 1. The name of the block is SMC_DIR (from Simocode Pro V 7.0 library).The FB no. is FB2004. I am giving a brief of the problems we faced:First we inserted the block in the chart. Then when we tried to compile the program it was asking for an upgradation of the Block OB_BEGIN. If we select no then the compilation stops. If we select yes the compilation continues. At the end an error message is showing. E: The Generate Module Driver found one error.The error is as follows: The block OB_BEGIN exists more than once in the program. Before the block was inserted in the program the compilation was giving no errors.It will be helpful for us if you take a look at the software. AttachmentRack_med.zip (377 Downloads) |
11/4/2009 11:34 AM | |
Posts: 467 Rating:
hello shambo, to solve your problem it is necessary to test your software with our specialists. Please send your problem and your software to: mailto:technical-assistance@siemens.com kind regards |
