(1)| 5/28/2010 8:59 PM | |
Joined: 5/28/2008 Last visit: 1/22/2026 Posts: 4522 Rating:
Hello Switch_639, Please try this FAQ: Which meaning have the error codes (xxxx:yyyy) in STEP 7? With best regards, |
Ayman Elotaify |
| 5/29/2010 3:28 PM | |
Hello, Here's bellow useful links to show CPU messages in WinCC / WinCC flex. How can you report S7 system errors in WinCC? How can you have system error messages from a SIMATIC S7-300 / 400 displayed in WinCC flexible? Hope this helps, |
Ayman Elotaify |
| 5/29/2010 4:19 PM | |
Joined: 10/7/2005 Last visit: 1/22/2026 Posts: 3054 Rating:
Hello Switch_639 I too would rather use "Report System Error" as perAyman's previous post (you appear to be using a Siemens HMI anyhow). If you do however insist ondisplaying the CPU diagnostic buffer events your way (as perTHIS link), then you will be able to find a comprehensive list of all Event ID's and corresponding texts in chapter 34 of the System Software for S7-300/400 System and Standard Functionsmanual. One last hint: Newer S7 CPU'shave a Web Server inbuilt which allows access to the CPU diagnostic buffer amongst other things. All you now need is a Webbrowser to display the CPU diganostic buffer. I hope this helps |
Cheers |
