(0)| 6/16/2010 6:37 PM | |
Joined: 10/7/2005 Last visit: 1/19/2026 Posts: 3054 Rating:
Hello SM exchange of non redundant data in a Software Redundant System is in principle quite simply (which is possiby the reason that there is no "in depth" pre-programmed example for it). Chapter 5.9 of the SIMATIC S7-300/S7-400 Software redundancy for SIMATIC S7 manualhas quite a good explanation on what to do to use this feature and even some example code on how to use the DB's to exchange/map non redundant I/O's via it. I hope this helps to get you started. |
Cheers |
