(0)| 12/14/2010 8:42 PM | |
Joined: 10/12/2006 Last visit: 12/4/2025 Posts: 206 Rating:
Hi, 1. write a loop. or 2. try fc103 Regards Zenta |
| 12/16/2010 4:11 PM | |
Posts: 34 Rating:
Thnx Zenta and Uel123, Uel is it possible for u to give example for SCL array and STL,LAD example only for 2-3 steps of level(means 1Cm-to-3Cm)?? Thanks.. |
| 12/17/2010 6:55 PM | |
Joined: 1/29/2006 Last visit: 1/18/2026 Posts: 451 Rating:
Hey! // now, lets write a small FC, which will look for volume according to level! FUNCTION FC200: VOID // Output variables: // temporary variables: Level_cm_real:REAL; END_VAR // code beginns here: // at first, let us convert actual level (in Mtr) to actual level in cm: In attachment, there is also a small project to demonstrate that. I have tested it only with simulator!! You must fill in the data in DB 200, with values of your customers data table for volume acc. to level. Simply, open DB and then switch the view to Data View and then fill in your values (each line for each cm!), then save changes and download data block. ... have fun! uel123 AttachmentForum_plc_eng.zip (211 Downloads) |
| 12/18/2010 8:14 AM | |
Posts: 34 Rating:
Thanks UEL for ur kind reply.. I am going to try ur given solution and willb back if need any help!!!!! |
