(2)| 7/3/2011 10:35 AM | |
Posts: 88 Rating:
Can Any body please tell me how is it possible to make several data structures in one data block? |
| 7/3/2011 10:48 AM | |
Joined: 1/28/2009 Last visit: 1/5/2026 Posts: 6892 Rating:
Hi Check the attachment for an example,When the first structure is done, create the next one after "END_STRUCT" of the first on, and so on. Regards Attachmentstruct.pdf (1030 Downloads) |
| 7/3/2011 1:58 PM | |
Check the modified version of your uploaded screen shot.The area highlighted with the red line is the region you can define the variables.Also,check the attachment for a sample program for a DB which contains 3 STRUCT. As the uploaded picture shows, create a blank row by "declare line before selection" .In this blank row you can assign a name to the variable and data type. select complex data type and then structure.It is not too difficult.Try it Best regards Attachmentstr.zip (279 Downloads) |
| 7/3/2011 2:14 PM | |
Posts: 88 Rating:
Dear Hdhosseini , |
| 7/3/2011 2:41 PM | |
The attachment is deleted and Some comments added on your snap-shots besides the sample program. Check it! |
