8/24/2011 10:48 AM | |
Posts: 376 Rating:
Hello, between SiemensPG and PLC S5-100U you can use the cable with the order number 6ES5734-2BD20. More information about this cable finds you here: http://support.automation.siemens.com/WW/view/en/217863 Note! In this document is PG7xx described. The cable with the order number 6ES5734-2BD20 is also relevant for other Siemens PG (Field PG, Power PG). Your write: Is it possible that I use MPI port which is used to s7 connection know? My answer: No, this is not possible. This isanother protocol. For the STEP 5 Online communication with a S5-PLC will use the AS511 protocol. On your PG you must use the programmer software STEP 5. I think the last current version was V7.23. The manual for the STEP 5 software finds you here: http://support.automation.siemens.com/WW/view/en/1175533 You find further information about the topic STEP 5 (Software, Hardware) here. http://support.automation.siemens.com/WW/view/en/27229639 I hope this information helps you a little. Best Regards Azteke0110 |
