10/27/2012 9:22 AM | |
Hello, Please have a look at the following manuals: SIMATIC Distributed I/O System ET 200S 2AI I 2WIRE ST analog electronic module (6ES7134-4GB01-0AB0) You will find all details there. Regards, Marcjan |
Problem solved? |
10/27/2012 11:14 AM | |
Hello, It's 2 wire 4 to 20 mA module, so the module provides power to the sensor (24V) over the same line as the analog signal (loop power) , if you have a sensor or anlog device with own powersupply you need 4 wire module like this one. Please don't connect your analog device to this module, it will end up in smoke. Regards, Marcjan |
Problem solved? |
