7/23/2014 5:09 AM | |
Posts: 1064 Rating:
I am not sure what your problem is You have 2 fb with the same number and different instance datablocks this should be no problem |
7/23/2014 6:58 AM | |
Joined: 3/24/2009 Last visit: 7/9/2024 Posts: 535 Rating:
Dear aoneeverything, I agree with playerslight, that there shouldn't be a problem. Are you sure, that all your blocks (escpecially the instance-DBs) are loaded to your Plc(Sim)? I the problem still persists, please give us some more details about the behaviour (error-codes, diagnostic-buffer, ...) Best regards, yy1 |
7/23/2014 8:48 AM | |
Joined: 10/7/2005 Last visit: 9/8/2025 Posts: 3049 Rating:
You could of course also simply do what's described inHow can you monitor a block with the desired call environment in STEP 7? |
Cheers |
7/23/2014 11:46 AM | |
Posts: 5 Rating:
Thank you for the answers guys! @William B.I determined the problem on PLCSIM, the SF indicator is red! I guess that your suggestion is right. On the picture herewith, you see the simulation on PLCSIM and OB1. Regards, Achraf
