8/22/2014 11:21 AM | |
Posts: 1058 Rating:
Hello Veeios, actually this module should work with that type of CPU. If there is a problem with your version V3.1.3 only a Siemens expert could answer, but I dont think so. Did you switch off power before inserting IF 964 DP module? If you insert module while power on, the module can be damaged and thus will not be working. Look here for details on installing: S7-400 and M7-400 Programmable Controllers Hardware and Installation regards |
8/25/2014 8:31 AM | |||
Joined: 8/22/2014 Last visit: 10/22/2024 Posts: 23 Rating:
Hello ,eisenpferdreiter
