1/11/2006 1:24 PM | |
Posts: 3149 Rating:
Hi gnook, in your WinCC online help you can find some more info about the configuration tool and how to handle it: smarttools > WinCC configuration tool http://support.automation.siemens.com/WW/view/en/13681075 Anyway you should check the smart tools > Variable Export/Import as well. If you export your existing tags to a csv-file you get a good example how to format the data. => this works with deactivated RT. Nemo |
