(0)| 1/12/2016 5:41 PM | |
Joined: 9/27/2006 Last visit: 1/6/2026 Posts: 12479 Rating:
Hello Emile; I am not sure that this is going to be easy, or cheap. You want 4 separate measurements of power from the generators; do you have any requirements of measurement class (or accuracy percentage)? It would appear you are looking for 3-phase powermeters, so I would suggest you look at Sentron PAC 4200 powermeters, one per generator and a central display, such as a Simatic panel with WinCC Flexible: Displaying
data of SENTRON PAC3200 / PAC4200 in WinCC flexible via über Ethernet https://support.industry.siemens.com/cs/ww/en/view/37450303 You could use a simple function In WinCC Flexible to add the 4 instantaneous power values the sum. Hope this helps, Daniel Chartier |
