(0)| 2/12/2019 4:02 PM | |
Posts: 31 Rating:
Hello, I have a V20 VFD and I want the drive to use a full speed setting (60Hz) unless digital input 3 is on and then I want the drive to use a programmed fixed frequency. I am trying to figure out P1000. I need help with determining which selection to use. ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 2/13/2019 9:42:52 AMNew subject after splitting |
| 2/13/2019 11:28 AM | |
Joined: 10/11/2006 Last visit: 1/16/2026 Posts: 6068 Rating:
Hello, |
With best regards, |
| 2/13/2019 3:19 PM | |
Joined: 3/27/2008 Last visit: 12/30/2025 Posts: 1235 Rating:
Does this help. select the two speeds as required. Also P1080 will have to be increased to 60Hz to allow the higher speed.
AttachmentV20 2 speed connection..pptx (494 Downloads) |
| 2/14/2019 6:03 PM | |
Posts: 31 Rating:
I will give these a try. Thank you |
