2/17/2023 8:21 AM | |
Joined: 1/16/2023 Last visit: 5/8/2023 Posts: 7 Rating: (0) |
hello everyone, i am a beginner in PLC Programming, i would like to make motion control in Tia portal using Driver Siemens S110 and PLC S7-1200, i have add a GSDML file to the TIA but when i use a technology object, i am success for configuring, however when i want commissioning the driver i get no response from motor, in the other sidei get the value of position and velocity. do you know guys what that's happening?
Attachmentvalues.pdf (592 Downloads) |
2/20/2023 9:51 AM | |
Joined: 10/11/2006 Last visit: 10/14/2024 Posts: 5913 Rating: (809)
Hello, S110 is not integrated in TIA Portal. So you have to use a GSDML to connect to TO (Technolofyobject). https://support.industry.siemens.com/cs/ww/en/view/48924746 https://support.industry.siemens.com/cs/ww/en/view/92022677 For commisioning S110, you have to use STARTER. |
With best regards, |
2/22/2023 4:40 AM | |
thanks for your fast response, i already done to generating the GDSML when i want to use Technology object with profidrive the module of driver doesn't seen, can you tell me what is the problem?AttachmentTO.pdf (777 Downloads) |
2/24/2023 8:30 AM | |
Thanks for the solution, i am sorry but i still confuse, why the telegram doesn't seen, what's wrong with my gsd file. is it coming wrong when setting in starter, or i lost a step for the configure it, can you tell me? AttachmentDoc2.pdf (478 Downloads) |
2/25/2023 8:55 AM | |
Joined: 5/12/2006 Last visit: 10/14/2024 Posts: 22411 Rating: (3017)
expand the three complete, unclear what is you problem now |
