8/14/2022 7:46 PM | |
Joined: 8/14/2022 Last visit: 8/15/2022 Posts: 1 Rating: (0) |
Hi, On Micromaster 440 I have problem. I would like to connect end switch to digital input 5 and when switch is active I would like digital output 1 to be active and stays active until end switch is active. I hope I explain it what I want. ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 08/15/2022 11:40:58New subject after splitting Last edited by: Milos1975 at: 08/15/2022 11:56:54 |
9/19/2022 6:29 AM | |
Joined: 6/19/2019 Last visit: 7/10/2024 Posts: 697 Rating: (73) |
It's hard to do because with digital input control your drive and you whant directly then input active give output. I don't know how your drive is controlled, if you don't use DC brake maybe you can define by your Discrete input : DC brake enable, and output you will see DC brake active.But then you need configure for DC braking parameters what it will not stop your motor AttachmentSiemens Micromaster 440 Manual - Siemens-Micromaster-440-Manual.pdf (577 Downloads) |
