7/2/2025 4:37 AM | |
Joined: 1/21/2013 Last visit: 9/15/2025 Posts: 4110 Rating:
Hi, To simulate the WinCC Unified Comfort Panel, you need the SIMATIC WinCC Unified PC RT V20. The applications you mentioned, SIMATIC Runtime Manager and WinCC Unified Configuration, are included in this installation. You should also install the latest update. Kind regards |
7/4/2025 9:35 AM | |
Joined: 8/3/2009 Last visit: 9/15/2025 Posts: 16409 Rating:
Hello get sure you have to set up your Runtime installation also correctly before using it: https://support.industry.siemens.com/cs/de/en/view/109806850 Bye Murof |
