6/17/2013 7:51 AM | |
Joined: 1/26/2011 Last visit: 8/11/2022 Posts: 243 Rating: (67) |
Hello, the easiest way is to look at this application example. http://support.automation.siemens.com/WW/view/en/23942303 there is a STEP 7 V5.X project for download available. You create a new STEP 7 project and add a pc-station in the Harware-Configuration you just have to add the WinAC RTX Version which you are using on your IPC. I also think that this should be described in this application example. Maybe this can also be interesting for you: http://support.automation.siemens.com/WW/view/en/67121011 bigfoot |
7/9/2013 5:53 PM |
Posts: 54 Rating: (3) |
your post is really enriched and also helped me a lot. - pk2_kdh
11/21/2018 11:05 PM | |
Posts: 2 Rating: (0) |
Thanks for the information [snip] |
