(0)| 8/31/2005 1:40 PM | |
Joined: 8/10/2005 Last visit: 4/9/2024 Posts: 1486 Rating:
Hello, here is a solution: You must put behind each H-CPU a CP1613. For redundant structure you connect the two CPs. Then you must insert the CPs in the PC (WINCC). You need the software RED-CONNECT for the walked. All steps are more near described in the H-System manual in chapter 8. "Manual: Automation System S7-400H Fault-tolerant Systems" http://support.automation.siemens.com/WW/view/en/1186523 I hope I could help. |
