(0)| 6/29/2023 12:09 PM | |
Joined: 2/7/2013 Last visit: 4/23/2025 Posts: 8 Rating:
Thank you for your reply, explaining that since v 5.5 the WebServer is de-activated by default. PLEASE PROVIDE more DETAILS on how to activate.!!! We are using Simotion (Scout) since ten years in the power plant sector in combination with a self made WEbHMI. Starting with v4.4 and including v5.2 everything worked well. Now we are totally blocked with v5.5 and the PROBLEM is, that the check box '...web server auf dieser Baugruppe aktivieren...' is existing since years and it is activated since years in our systems, also with scout v5.5 it is activated but the Webserver does not respond at all. PLEASE EXPLAIN, if there is now a new checkbox or setting or whatever!!!!!!! Thank you very much!!! ------------------------------------------------------------------------------------------ |
Last edited by: DerZar at: 06/29/2023 13:20:24looks like Simotion and / or WebServer is refusing but running Last edited by: Jen_Moderator at: 06/30/2023 09:05:50New subject after splitting |
| 7/5/2023 12:02 PM | |
Joined: 10/11/2006 Last visit: 1/21/2026 Posts: 6072 Rating:
Hello, please check this setting. Now the default is "deactivated". Chapter 3.2. https://support.industry.siemens.com/cs/ww/en/view/109820425 |
With best regards, |
