12/2/2019 11:15 AM | |
Joined: 10/1/2013 Last visit: 9/10/2025 Posts: 605 Rating:
Hi tim-011, keep in mind that you'll have to make a reset via the "Reset_Reader" block before reading or writing tags. Afterwards you can read a tag and you'll find the read data in the "Ident_Data" variable as you suspected. Check out this example: Also think about using the "Inventory" block instead of read or write. The Inventory command returns the EPC-IDs of the accessible transponders. |
12/6/2019 8:54 AM | |
Joined: 8/14/2018 Last visit: 4/4/2025 Posts: 14 Rating:
Thanks a lot, that really helped me. I had like no experience in Ident |
