10/4/2024 9:18 AM | |
Joined: 8/3/2009 Last visit: 9/2/2025 Posts: 16290 Rating:
Hello Its hard to say what went wrong. First you should check if everything is set up correctly: https://support.industry.siemens.com/cs/ww/de/view/59216666 Then which changes do you have made exatcly? (not all changes can be loaded with delta download) Which exact WinCC and Step7 Version do you use? Bye Murof |
