(0)| 1/7/2025 3:17 PM | |
Joined: 10/17/2007 Last visit: 1/21/2026 Posts: 4579 Rating:
I have known SIMODRIVE 611A from 1992 the 1st year when Siemens released it, when I worked as Siemens employee. But I have never meet the case as you described. let me make long story short. What is your role in company ? Are you able to test run spindle with CNC --that means extenal enable and using battery box to terminal 54/14 . Also 16/21 KW E/R module is not so much cost. so I don't want to spend so much time to troubleshoot it, If you really need spare parts go to online market such as eBay to purchase one . I attached 611A manual you can look it to see it is easy for you
Attachment57453743611A_IA.pdf (736 Downloads) |
If you like my comments please |
| 1/7/2025 5:01 PM | |
Joined: 12/19/2024 Last visit: 1/9/2025 Posts: 13 Rating:
I also tested the module on the CNC, but I did not apply voltage to pins 56 and 14 separately with a battery to test it. |
| 1/7/2025 5:02 PM | |
I do maintenance and repairs for several factories on a freelance basis |
| 1/7/2025 5:05 PM | |
I read the manual but couldn't figure anything out. |
| 1/9/2025 12:20 PM | |
I will show you how test spindle #1-You should know how to enable power supply E/R--that should be easy jumper Terminal 63--9, ter.64--9--Green LED off jumper ter.48-9 and ter.112--9---Yellow LED On , you will have DC600V on P600 and M600 #2--on spindle control see my picture attached 56/14 connecter battery box (justible 0-9V) using 3 switches connect one by one Ter 9. to 663, to 65, and to 81 #3--after you enable E/R module , set switch to on as 663, 65,last to 81, give a little DCV to 56/14 you spindle should be running if not like this you need take picture and send to here
Attachmentsp_ter.pdf (774 Downloads) |
