2/12/2025 7:38 AM | |
Joined: 8/3/2009 Last visit: 9/15/2025 Posts: 16409 Rating:
Hello jroitner the last Update for WInCC V7.4 Sp1 was in 05/2024: https://support.industry.siemens.com/cs/de/en/view/109955792 Also WinCC V7.4 Sp1 is a canceled product since 10/2024 So there will be no updates or further development on this Version. I would say there is also not extended SQL Support included. If you want to have an uptodate patched system you should consider upgrading your WinCC to a WinCC V8.1 or V8.0with newer OS and SQL Support Bye Murof |
