(0)| 3/7/2025 12:50 PM | |
Joined: 8/3/2009 Last visit: 1/21/2026 Posts: 16653 Rating:
Hello Papiksub If you do not want to dynamize the tag directly to the output value property of the IO Field, then you can use a Script with tag trigger at the: and for Writing into the Tag you can use a Script at: If you need basic help for reading or Writing Tags in scripts then have a look at this: https://support.industry.siemens.com/cs/ww/en/view/109976624/118089674379 https://support.industry.siemens.com/cs/ww/en/view/109976624/45951188235 Bye Murof |
Last edited by: Murof at: 03/07/2025 12:52:56If this Information really helps, you could use the Rate function |
