(0)| 3/19/2025 2:43 PM | |
Joined: 8/3/2009 Last visit: 1/20/2026 Posts: 16653 Rating:
Hello AutoGen_1235749 here you will find many information about virtualisation:
Siemens do only test a few combinations and gives guarantee for functionality.In the most cases if you take kare about the OS compatibility of WinCC and use Ethernet it will not cause any trouble. But you have to test on your own using these mixes systems in one ESX environement. Bye Murof
