(0)| 4/7/2025 10:04 AM | |
Joined: 10/5/2024 Last visit: 6/24/2025 Posts: 1 Rating:
I have a problem all the safety cards are flashing red
| 4/15/2025 12:38 PM | |
Joined: 5/30/2022 Last visit: 1/19/2026 Posts: 634 Rating:
Hi, I recommend you to check: 1- The diagnostic buffer 2- Check the DB associated to the security module (online connection). 3- Check if you have programmed a depassivation: Safety: Passivation and Reintegration of F-I/O 4- Are there errors in the SENDDP and RCVDP blocks? Attach screenshots
If this information really helps, you could use the Rate function. |
