7/14/2025 1:50 PM | |
Joined: 8/3/2009 Last visit: 9/17/2025 Posts: 16447 Rating:
Hello AutoGen_339775 first of all you should check on any WInCC stations this: https://support.industry.siemens.com/cs/ww/en/view/22132850 Then what dows not work exactly, are the buttons gread out? which functinoality do you use on the Buttons? (Script, direct function or similar) Bye Murof |
