8/30/2023 12:37 PM | |
Joined: 8/12/2021 Last visit: 9/24/2024 Posts: 324 Rating: (29) |
Hi! I would recommend that you check the physical configuration to see if there is a problem in any module. The meaning of the LEDs usually appears in the manuals. I'm not sure if it's your model, but here's an example.
