10/28/2011 1:55 PM | |
Posts: 739 Rating:
Hi, without output chokes 50 screened / 100m unscreened motor cable. with output chokes:? out put chokes still not available for G120C The MICROMASTER 440 is an established drive, you can do: without output chokes 50 screened / 100m unscreened motor cable. with output chokes 100 screened / 300m unscreened motor cable. Catalogue: http://intranet.automation.siemens.com/mcms/infocenter/content/de/Seiten/order_form.aspx?nodeKey=key_516851&infotype=catalogs (may be you can use MM4 chokes – it´s not tested, and you´ll do it on your own risk, but it should work) |
