5/20/2020 2:23 PM | |
Posts: 45 Rating: (0) |
Do you know, when approximately this image will be released by you? |
5/24/2020 9:30 PM | |
Hi, Could you provide me with this IOT2050 image? I have DM'ed you. Additionally, can you tell me if this image will contain RT to run PROFINET on IOT2050? |
5/25/2020 8:59 AM | |
Joined: 4/28/2015 Last visit: 6/3/2024 Posts: 3345 Rating: (379)
Hi, the image I will send (also the one which will be available for download) does not contain the RT patch. But you can build this version on your own, like described on github. Here is an instruction how to setup a build environment from scratch. Use
Best regards! |
5/25/2020 9:34 AM | |
Okay, so I would need to create this VM just to prepare this image? So the VM is created just for that? I will not use it after making this image? |
