6/23/2021 6:12 AM | |
Joined: 4/3/2019 Last visit: 10/19/2023 Posts: 6 Rating:
Hello I want to know , the firmware of CPUs in redundancy mode must be same? I have 2 CPUs that are in redundancy , model :417-4HT14-0AB0 first CPU firmware is v4.5.2 and second is v4.5.3 can i use from these CPUs on my system? or my firmwares must be same? thanks, ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 06/23/2021 09:05:21New subject after splitting |
6/23/2021 9:41 AM | |
Joined: 3/5/2014 Last visit: 8/5/2022 Posts: 5521 Rating:
hi, yes FW must be the same on both CPU, without any exception. regards, |
FCK WAR! |
6/23/2021 2:29 PM | |
hi mpy65, its easy: search for the product here in SIOS. Therefore you find a searchbar in the upper right. Then filter for downloads, and you will find your FW-Update file download: you´ve seen I had already searched for it. Here´s the direct link: Download Operating System Updates V4.5H CPU412-3H / CPU414-4H / CPU414-4H PG / CPU417-4Hhope this helps, regards, |
FCK WAR! |
