12/18/2012 2:57 PM | |
Posts: 3037 Rating:
Hello, Do you set the rigth Ethernet interface in your PC/PG interface? You do not use "TCP/IP(Auto)". See the chapter 3. How do you configure a connection between WinCC flexible Runtime (PC or Panel) and a SIMATIC S7-300 / S7-400 via Industrial Ethernet? Tweety |
12/19/2012 11:46 PM | |
Posts: 6 Rating:
ok thanks for your help. the pg/pc interface was the problem |
