(19)| 9/30/2016 9:41 AM | |
Posts: 8 Rating:
Dear community, in this thread you find all available information about the IOT2000 including how to get started, necessary infrastructure, tutorials and application examples provided by Siemens and the community. Useful links to get started with SIMATIC IOT2000
Starting with Node-RED as graphical programming language Application examples
Useful information for Node-RED
Starting with Arduino programming on IOT2000
Starting with C/C++ Programming using Eclipse Tutorials
Application examples provided by community
Further guides and application examples Programming IOT2000 and building IOT2000 image
Useful information SIMATIC IOT2000 I/O module
Useful software
Required / useful hardware
IOT2000 in education
Other websites with IOT2000 projects
Best regards, Your IOT2000 team |
Last edited by: IOT2000_Moderator at: 9/11/2017 1:32:46 PMLast edited by: IOT2000_Moderator at: 9/11/2017 1:33:40 PMchanged welcome post to this guide Last edited by: IOT2000_Moderator at: 11/3/2017 3:06:28 PMadded Arduino board support and node-red nodes for IOT2000 Last edited by: IOT2000_Moderator at: 11/22/2017 9:43:24 AMLast edited by: IOT2000_Moderator at: 9/10/2018 3:44:35 PMadded application examples Last edited by: IOT2000_Moderator at: 9/10/2018 3:46:16 PMLast edited by: IOT2000_Moderator at: 9/26/2018 4:26:30 PMadded security tips Last edited by: IOT2000_Moderator at: 9/26/2018 4:26:57 PMtypo Last edited by: IOT2000_Moderator at: 11/12/2018 8:10:17 AMadded MindConnect example Last edited by: IOT2000_Moderator at: 2/12/2019 4:20:28 PMadded PN Driver and RT Image |
| 3/15/2019 12:45 PM | |
Posts: 1 Rating:
Hey, guys I had some troubles using the official IOT User Guide, especially with network configuration. So, I developed a new one with full informations about it. I used an IOT2040 and performed communication with a Step7 1200 through TIA Portal and a MicroLogix through RSLogix If you want to use a Database, I recommend you to use Maria DB, wich official tutorial is available at Siemens Forum. AttachmentIOT2040_Tutorial-compactado.pdf (4880 Downloads) |
| 2/5/2020 7:47 AM | |
Posts: 9 Rating:
Thanks bergmanu for your prompt feedback. Much appreciated!! The node-red in the latest image file v2.6 is v0.20.7. I found the link below from nodered.org, saying node.js version 8.x is "going End of Life December 31st 2019"... https://nodered.org/docs/faq/node-version Would this affect the node red running in our IOT2040/2020? I have also included the screenshot of the info from nodered.org in the attachment. |
