9/13/2022 11:10 AM | |
Joined: 4/23/2010 Last visit: 11/23/2024 Posts: 8092 Rating:
Hello vjveluri, You have open topic in wrong conference. You should have opened it in SIMODRIVE Converter system product conference since you mentioned part number is 6SN1123-1AA00-0CA0 is 611 drive 50A power module. Please check the control card of this power module (number 6SN111x-xxxx). Fault code 6 means hardware failure of control module, so you need to replace control card. Hope this helps. |
Last edited by: PISCEAN 2010 at: 09/13/2022 11:12:16Last edited by: PISCEAN 2010 at: 09/13/2022 11:14:27 |
9/13/2022 10:53 PM | |
Joined: 10/17/2007 Last visit: 9/12/2025 Posts: 4449 Rating:
you have no detail story--what happen? it was running good yesterday. ? post picture of your drive see attached pic you may need to replace the drive module (if you have same module or same machine, you can try to switch for test)
AttachmentFEED_tb-shooting_6.pdf (938 Downloads) |
