(0)| 6/11/2024 6:30 AM | |
Joined: 11/8/2023 Last visit: 12/1/2025 Posts: 4 Rating:
Dear All members, Good day we have an Siemens Line Filter for Active Line Module(I/R) ( 6SL 3000-0BE23-6AA0 ) along with HF reactor (6SN1111-0AA00-0CA1) connected to the simo drive power module ( 6SN1145-1BA02-0CA2). 3 phase 380 volts supply. the line filter is currently burn out , so my question can we bypass the 3 phase supply 380 volts from main contactor to HF reactor as our Line filter is damaged. if we did, can we face other problems due to this. because due to this our plant is under breakdown and the same part will take time to deliver , in that period is it possible to run the Simo Drive power module (6SN1145-1BA02-0CA2) without Line Filter for Active Line Module(I/R). kindly please check the attached highlighted drawing awaiting of your valuable feedback thank you Attachment611U Drive power supplier.pdf (1081 Downloads) |
Last edited by: AutoGen_1427206 at: 06/11/2024 07:35:14Last edited by: AutoGen_1427206 at: 06/12/2024 05:54:26 |
