(0)| 6/2/2025 1:42 PM | |
Joined: 8/3/2009 Last visit: 1/20/2026 Posts: 16653 Rating:
Hello AutoGen_9871517 are you sure http is correct and not https? Can you show a simple html page from the webserver? Which Image version do you run on the panel? (in simulation the Webcontrol of the Advanced RT is used and so the webcontrol on the panel can behave different) does it work with a website that is located on an USB device on the panel?: Bye Murof |
Last edited by: Murof at: 06/02/2025 13:44:00If this Information really helps, you could use the Rate function |
