(0)| 5/13/2025 2:31 AM | |
Joined: 11/8/2017 Last visit: 1/16/2026 Posts: 361 Rating:
Hi, For the integration of the KNX devices, there's a link below to a video that shows the basic process (with a DXR controller in ABTPro). This is hopefully of some use to you with your PXC3 controller. https://www.youtube.com/watch?v=YxD5_773Gss In ETS, if you are able to map the actual measured air volume flow rate to a KNX group address - then use this value in for your software for any volume control that you need to configure in order to position the actuator. You may have it already, but you will need to download the ETS product database for the actuator, and import this into ETS. Regards, |
Last edited by: CJ. at: 05/13/2025 02:33:08Last edited by: Moderator_Lan at: 05/13/2025 07:33:44Video embedded. |
