(0)| 12/15/2024 12:30 PM | |
Posts: 1 Rating:
FOR MICROWIN S7-200 SMART CPU FIRMWARE V02.08. WHICH SOFTWARE VERSION IS APPLICABLE? WE HAVE USED MICRO S7200 SMART V2.6 AND FOUND THAT PROGRAM BLOCK AND DATA BLOCK ARE DOWN LOADED SUCCESSFULLY BUT NOT SYSTEM BLOCK. IT "GENERATE UNSPECIFIED ERROR". ON PLC INFORMATION, WE FOUND NO ERROR. ON COMPARING PROGRAMM BLOCK AND DATA BLOCK ARE PASSED, BUT FOR SELECTION OF SYSTEM BLOCK, "IMPROPER AUGMENT ENCOUNTERED" ERROR IS DISPLAYED. ALSO EXPANSION MODULE SHOW NO ERROR EXCEPT GREEN LED BLINKING. IT IS HAPPENING WITH TWO CPU. OUR LAPTOP IS USING WINDOW 7 SP1. REQUEST TO KNOW WHAT VERSION PROGRAMMIMG SOFTWARE IS TO BE USED OR FIRMWARE NEEDS UDATING OR REQUEST TO PROVIDE SOLUTION ------------------------------------------------------------------------------------------ AttachmentPLC SYSTEM DOWN LOAD ISSUE S7-200 SMART 24-11-24.pdf (996 Downloads) |
Last edited by: Moderator_Lan at: 12/16/2024 07:30:39New subject after splitting |
| 12/15/2024 4:21 PM | |
Hello; Stefan Arcularius has already explained that the S7-200 Smart (and the Microwin Smart software) are limited to the Chinese and Indian markets, and the volunteers in this forum have little documentaion and experience with these PLCs. Support for the S7-200 Smart family of CPUs is provided by Siemens India. If you want to contact them to ask for help with firmware versions, have a look at the introduction page for the S7-200 Smart family from Siemens Global: https://www.siemens.com/in/en/products/automation/systems/industrial/plc/simatic-s7-200-smart.html You will find an address and phone number to reach Siemens R&D in India, you can try to contact their support technicians that way, or you can use the Contact button in the same page to write a message to them. Hopefully they will answer you correctly and quickly. Hope this helps, Daniel Chartier |
