(4)| 8/31/2018 8:28 AM | |
Posts: 156 Rating:
Hi AutoGen, the axis's modulo length is a restart-relevant tag. https://support.industry.siemens.com/cs/ww/en/view/109749263 Best Regards |
| 8/31/2018 8:44 AM | |
Joined: 10/11/2006 Last visit: 1/16/2026 Posts: 6047 Rating:
Hi, it works with the WRIT_DBL command and a restart of the technology object. You can see how it works in detail in the attached document. AttachmentWrite_TO_Tags.pdf (2037 Downloads) |
With best regards, |
| 11/29/2024 8:59 AM | |
Joined: 3/2/2007 Last visit: 1/14/2026 Posts: 1002 Rating:
Can we also change the axis gear denominator in the same way ? |
... thank you ... |
| 12/2/2024 9:52 AM | |
Joined: 11/4/2011 Last visit: 1/14/2026 Posts: 280 Rating:
Hi there, Generally I can only advise to make yourself familiar with the accessability of the TO's parameters. From my point of view, this is a quite basic point to understand, when working with these objects.
| 4/29/2025 11:02 AM | |
Joined: 10/2/2017 Last visit: 11/21/2025 Posts: 2 Rating:
Yes, you can Example of programmatic change of technology object settings from machine setup: |
