(0)| 5/21/2025 10:06 AM | |
Joined: 5/21/2025 Last visit: 10/20/2025 Posts: 5 Rating:
just to add question does it require a ethernet rj45 cross over cable maybe??? |
| 5/21/2025 10:07 AM | |
also tried to ping the iot2050 on a pc with a rj45 socket and it did not work. |
| 10/20/2025 1:50 PM | |
Joined: 3/12/2024 Last visit: 1/16/2026 Posts: 232 Rating:
Hello rail8, what IO2050 are you using? Basic? Advanced? Do you know the exact boot order of the device? Maybe it is booting from emmc (IOT2050 Advanced) and not from the sd card with your Example Image. Please follow every step of our IOT2050-Setting-Up-Example and have a specific look in the section Change boot order in in u-boot shell via UART connection. Is there an output on your serial connection via uart - if yes please share the output. I have the following setup: Host laptop - Delock usb to ethernet adapter - IOT2050 eno1 port BR |
