9/9/2009 9:45 PM | |
Posts: 13 Rating:
It looks like you are trying to adjust an absolute encoder... You may find the official instructions in the Siemens manual 1FT6_IA.pdf (Maintenance Three phase motors... 1FT6..., downloadable from http://www.automation.siemens.com/doconweb). Instructions are for 1FT6 but valid also for 1FK7. Short version: Try several times (as nulizhang presented already, thanks nulizhang). With some luck you will succeed in only few attempts. Long version: You may always contact your nearest Siemens service center (https://www.automation.siemens.com/partner/index.asp?HTTPS=REDIR®id=WW&lang=en&comptcid=o). |
9/5/2017 8:20 AM | |
Posts: 6 Rating:
You need special equipment to Read Rersolver Angle and set it to the Windings. We own such equipment here in DUBAI & install Encoders/ Resolvers on Servo motors. |
