(0)| 6/29/2021 8:34 AM | |
Joined: 4/28/2015 Last visit: 11/27/2025 Posts: 10970 Rating:
Hello, I expect in this case only configure connection inside HMI cfg (add HMI in TIA), select correct driver with correct PLC cfg as address and speed. Same you need set on HMI inside its internal cfg screens. You can then connect devices and check data exchange. Look to this FAQ what can be helpful: Connect HMI components with S7-200 CPU |
Last edited by: Duris_I at: 06/29/2021 08:35:06Last edited by: Duris_I at: 06/29/2021 10:14:16With best regards... |
| 7/10/2021 10:34 AM | |
Joined: 6/9/2017 Last visit: 9/16/2025 Posts: 3 Rating:
thanks for your answer. Can you see my configuration?
Attachmentem277_1.zip (484 Downloads) |
