9/3/2021 7:32 AM | |
Joined: 9/19/2014 Last visit: 3/20/2025 Posts: 71 Rating:
Hello qwazee, can you give advice with using the siemens counter, it is perfect work with simulation but not worked with real line. Real speed is 600 bottle in minute. But a Fc100 count about 60-75 in minute. The problem is not in photocell. ------------------------------------------------------------------------------------------ |
Last edited by: bandr at: 09/03/2021 07:32:28Last edited by: Jen_Moderator at: 09/06/2021 05:58:03New subject after splitting |
9/3/2021 9:13 AM | |
Attachmentforum.zip (321 Downloads) |
9/3/2021 10:55 AM | |
The process here [snip].
9/6/2021 3:20 PM | |
Joined: 3/5/2014 Last visit: 8/5/2022 Posts: 5521 Rating:
hi bandr, this application sample can´t be accurate enough for the speed of your task. Maybe when you use the OB35 with an interrupt of 1 or 2 ms. I wouldn´t use this application sample, especially not in your situation. Because you have a better option. Why don´t you use the internal HW counter of your 313C? Look into the suitable manual therfore: Counting – Description of Function hope this helps, regards, |
