(0)| 3/25/2009 1:35 PM | |
Joined: 3/21/2006 Last visit: 10/16/2025 Posts: 10239 Rating:
Hello Let's start with Simoreg settings. To do this I suggest you to use DriveMon. Also you'll need cable to establishe connecion with drive. You can find drawing for cable here in this forum. How to work with software look at SIMOREG DC Master 6RA70; software version 3.1. If you prepared connection and set this parameters let me know. Will continue with settings for profibus parameters.(data which will be exchange with CPU). regards |
| 4/22/2009 11:26 AM | |
Joined: 5/7/2008 Last visit: 12/12/2025 Posts: 41 Rating:
Hello! P433 - setpoint input (fixed setpoint) P443 - setpoint input (crawling setpoint) You could place Your setpoint in many place's. Just look in manual and check where do You want to put Your setpoint, i suggest P433 (then You could choose other setpoints like fixed etc.) Attachmentsetpoint.pdf (841 Downloads) |
| 4/23/2009 8:38 AM | |
Hello! If You don't use oscilation/crawling setpoint/fixed setpoint, there is no difference betwen use P433 and P443. |
