6/9/2023 7:33 AM | |
Joined: 7/19/2016 Last visit: 8/7/2024 Posts: 1 Rating:
Hi i want communicate with my s7-1200 plc with profibus DP Slave to third party device (i.e ABB dcs m800 cpu ) as DP master, can anyone help out to communicate with example. Regards Santhosh ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 06/09/2023 10:47:36New subject after splitting |
6/9/2023 10:04 PM | |
Joined: 6/9/2023 Last visit: 7/1/2024 Posts: 12 Rating:
General instructions for the S7-1200 side of the configuration are at How do you connect a CM1242-5 as DP slave to a PROFIBUS system?, use the "DP Master and CM in Different TIA Portal Projects" use case. Instructions for the DP master will vary according to the Profibus master device used, but in general you will have use the GSD file from Download GSD File CM 1242-5 in the 3rd party configuration software. |
