(0)| 12/23/2025 2:41 PM | |
Joined: 3/14/2008 Last visit: 12/23/2025 Posts: 2233 Rating:
Hi, The term: “Zero cliënt” is only used with PCS neo, where you log in to the M&C server via a html5 browser. This is not possible with PCS7. You can use a OS client and access it via a thin client which uses a RDP session. |
