Industry Online Support
6/30/2011 4:56 PM | |
Joined: 7/2/2008 Last visit: 8/26/2024 Posts: 928 Rating:
Hello gru,Don't you have fail safe I/O modules? If you don't have fail safe modules then you don't have a SIL at all. No one can tell you what SIL you have without seeing your hardware configuration. So, you should upload your configuration here. Until you do so, you can take a look at the following links to check which configuration you have and then which SIL you have. F Systems: Wiring and Voting Architectures for ET200M F‑DIs and F-DOs SIMATIC Automation System S7-300 ET 200M Distributed I/O Device Fail-safe signal modules SIMATIC Distributed I/O ET 200iSP Distributed I/O Device - Fail-safe Modules Best regards. H-H |
