8/22/2011 11:00 PM | |
It's verry easy, if you use HSC0 i.e. you can read/ comparethe countervalue in Integer by just using the name hsc0 as input. Have no acces to my progams here, but can give some examples next day. Meanwhile you can have a look at the tips and tricks, if i'm right there are some Hsc tips in it http://support.automation.siemens.com/WW/view/en/1232912 Regards, Marcjan |
Problem solved? |
8/23/2011 1:56 PM | |
Joined: 8/22/2011 Last visit: 9/4/2025 Posts: 48 Rating:
Thanks for the answers guys. It helped. |
8/23/2011 2:50 PM | |
Oops, my mistake the operand must be HC1 not HSC1 Attached an example, it's in dutch sorry, but have a look at sbr13 there i use things like compare with hsc. I used a window (venster) where some bits are triggered (between i.e. 500 pulses - or + countvalue. If you need more help to read the program i can put some comments with it later. Regards, Marcjan Attachmenthsc.zip (277 Downloads) |
Problem solved? |
