1/31/2007 9:08 PM | |
Posts: 7 Rating: (1) |
Dear all, To control the flow througha solenoid valve (with a feed back signal) I have written a control program in Step7, used timers tosettime on and offfor opening andclosing the valve. Now I have to develop the PID algorithm anduse Pulse Width Modulation (PWM) to control this solenoid valve. (Feed back signal ->PID -> PWM -> the solenoid valve-> regualte time on/ off of the solenoid valve -> control flow of the solenoid valve). I have read some example about temperature PID control but I still confused how to begin with PID? how to use some availlable PID block like: FB41(TCONT_C); FB58(TCONT_CP) as well as how to organize a program with PID control step by step? How can I use PID in the mode of the Pulse Control or how to connect it with a available PWM intergrated in the Step 7? I'm just a begginer in PLC and in programming, would you be so kind to helpme and send me your advice to solve my problem! Thank you in advance! Your sincerely, T2007. My email: bangkokhanoi2007@yahoo.com |
2/1/2007 11:33 AM | |
Joined: 10/10/2005 Last visit: 10/18/2024 Posts: 1921 Rating: (136) |
Hello, regarding to your inquiry please find the FAQs (links) which do you will find in the internet by the custome support. http://support.automation.siemens.com/WW/view/de/18459342 http://support.automation.siemens.com/WW/view/de/16532187 http://support.automation.siemens.com/WW/view/de/2361324 With best regards |
