(0)| 9/1/2005 3:33 PM | |
Joined: 8/10/2005 Last visit: 4/9/2024 Posts: 1486 Rating:
Try to upgrade your CPU firmware, as older versions of the firmware does not support SFC12 Jan Ulvesten |
| 10/22/2005 5:50 AM | |
Posts: 17 Rating:
Hi all, Can give some information(detailed) about firmware. What it consist? Thanks in advance. |
| 10/23/2005 12:37 AM | |
Joined: 8/25/2005 Last visit: 12/30/2025 Posts: 1162 Rating:
Hello again, the best way to find out wether your CPU supported the SFC 12 is to following: Have a look online! If you will find the SFC on the CPU you can use it. If not, maybe a firmwareupdate may help. I found an older FAQ with a list of CPUs. Deactivating and Activating DP slaves Best regards Sabine |
