(0)| 5/11/2017 8:26 AM | |
Joined: 5/12/2006 Last visit: 1/16/2026 Posts: 22827 Rating:
Hello, this is a very very old IPC from siemens. A direct successor is not available or already phased out. from the prduct cancellation page you can see that the IPC 670 is the replacement but you shoulkd check if is possible for you to switch to ipc670 https://support.industry.siemens.com/cs/ww/en/view/8896355 A backup of the FI15 can't be used in the IPC 670, to use the backup you must buy a FI15 (ebay?) or recreate the project of the FI15 on the new IPC.
Christoph |
